i cant remember which distributor (TD??) is it supposed to be? Y8 head swap
i forgot the proper distributor model is used for the swap.
looking for the right TD## call sign for this swap.
the swap is for the EF civic D16A6 (single cam) OBD0 to the OBD1 VTEC d16Y8 (single cam) head.
so its basically the bottom is d16a6 single cam with vtec Y8 head single cam with obd1 conversion.
which dizzy?
i thought it was the TD80 but then i think i might be the TD42 or maybe the TD43 distributors.
can someone verify this.
thanks!
which dizzy?
thanks!
the td73u lines up with the three bolt holes but there is only one wire harness and i need to have two.
the td42 has the two wire harness but wont line up with the three bolt holes.
