rt auto tranny in park but will still move.. help
Ok background. My wagon is slammed btw. Put two new axles in my atuo rt wagon yesterday. Dr side smooth. Pass not so snooth. The axle poped out and about 2qt fluid came out. Got axle in good and now it makes a slight vibrating at 50-65 mph. Can feel it in my gas pedle. And today when i put it in park the darn thing would have drifted away if i wouldnt have pulled the ebrake fast. Can anyone help
    Did you make sure the axle snapped in place? It could be in but not all the way and might be causing your vibration. Not to sure about the transmission thing. Does in go forward or backward?
  • Both axles seem to be in and set. And yeah will go into drive and reverse.
  • Now when in drive or reverse my tranny makes a clattering.. Kind of noise. When in nutral it stops. Any idea guys. If my trans is bad im swapping to manual
  • Noise was a poped out driver axle. But after i put it back in it came out 5 miles diwn the road. Why?? Help please
    slammed! raise it up.. or possibly the c-clip is worn/gone on the axle
  • Well i got it. The local advanced auto gave me the wrong axle again. The inner splines diameter were small. Smh. Rebuild my old ones and in all good now
