Hydraulic SOHC S22 AWD transmission discussioon
Ive been on the hunt for a good condition 4wd transmission for the past year with no luck. So recently ive been pondering the jdm Awd transmission, the S22, as a substitute.
I know that there's a thread where some dude had one, but it never concluded if its a direct fit in our USDM wagons and more importantly, if anyone has *actually* made the switch.
Things to know:
I have a JDM dohc ZC, innovative steel mounts, and will be using the hush22 bracket to convert to hydro....
Can anyone chime in on this? I'm getting desperate for a new transmission....
Thanks
Things to know:
Thanks
Can anyone confirm if it will work?!?
If it is the same as this gearbox i dont see why it should not work, cable shifter looks the same.
http://www.ebay.com.au/itm/HONDA-GEARBOX-4WD-CONVERSION-EK9-EG6-INTEGRA-B16A-B18C-K20A-/221072341660?pt=AU_Car_Parts_Accessories&hash=item3378f03a9c#ht_1720wt_1144
although it doesnt have the SL gear iirc?
http://www.lingshondaparts.com/honda_car_parts_block_selection_C30.php?mod_01=15098
They look very similar according to these diagrams (scroll to the bottom)
If that one on ebay drops in price i might grab it.
I believe the front tranny mount wont fit, i dont know about the one that mounts to the chassis though. maybe looking through those diagrams can help you.
Part Numbers 3&8
http://www.lingshondaparts.com/honda_car_parts_selection_pfk.php?block_01=17SR401&block_02=B__4702&block_03=15098
Part numbers 5&9
http://www.lingshondaparts.com/honda_car_parts_selection_pfk.php?block_01=18SH501&block_02=B__4700&block_03=9327
Great to see finally someone doing it!!! Please keep us posted with results, how the gearbox feels etc.
Are you not able to bolt up the cable sensor into the gearbox?
There are still parts available for the S22 hydraulic one, im curious to see if the gears and synchros are the same.
They share virtually the same part numbers except for the chassis code. Has anyone pulled both boxes apart and inspected?
For example
EG RTSI S22
23431-P22-000 2nd gear
23521-P22-315 1st-2nd synchro set
RT4WD L3
23431-PH8-901 2nd gear
23521-PH8-505 1st-2nd synchro set
That's the one I was talking about. I may just purchase a synchro set and see Jo
