seats
ok all. so the prelude seats are badass but look to be a pita to adapt. leWolf, are del sol seats easier to fab in than the prelude seats?
then i also talked to one of my guys at work... he said that theres a nice drivers seat my color (blue) at his local junkyard he goes to all the time.
we are going next week, but if the passenger seat is good and the drivers seat isnt you say it will work? guess its worth a try. ill check
it out
it out
http://www.civicwagon.com/showthread.php?3534-DA2EE-seat-swap-who-knew-it-was-so-easy
So back to the prelude seats I have, I found a couple different links that gave me some more ideas.
Haydz, thanks for the links, those worked. I found lots of links that arent working yet, maybe later. I've spent 2 weeks searching.
Use the search function and all links it finds will work, only the quicklinks (up until now) were to ones not working
Also try use capital letters and hit the "enter" button when typeing a post, it makes it easier to read
Guess I need to remember high school English class, it's been 28 years since I had to use most of these skills.
Sorry, I guess I'm not used to having to pass a class anymore.
Anyway, I'll try to do better from now on.
Like I said, I have searched for 2 weeks and really only found a few links that were helpful.
If the quicklinks are working now, I promise I will go back and start all over.
If this seems sarcastic, I'm sorry. I wasn't expecting the Spanish Inquisition.
(Sorry, Monty Python reference, for those too young to remember)
Again, Thank You For Your Assistance!
Sorry, I had no idea!
I have another weeks' worth of work to do!
Thanks! I'm off!
What time is it in New Zealand?
It's almost 1 am in Ohio, USA.
Solid with 3 bolts, but it will need finished.
94 JDM Prelude Seats. Replaced all the stock wagon rails and mounts with my own fabbed up mounts. Super thick steel, cut, welded, and powdercoated, problem solved.
I thought I had seen that before......here no doubt
As for the seats they are very comfortable, but they are going to be taken back out and tossed in favor of my stock seats, since there was nothing wrong with them to begin with. This was just a quick one day fabrication to show that it can be done very easily. Trying to mate wagon mounts with seat brackets always seemed the difficult way to do things when you can just cut up some thick metal, weld it, powdercoat it, and be done in one day.
