Car Wont Turn!
Well im trying to get a civic wagon back on the road.
1990 civic wagon MT FWD. Blue
Duel point fuel injected.
Here's my problem
It’s been sitting for about 2years.
I drained all old gas and put about 5 gallons new gas in. Got a battery and hooked it up. Turn the key but it doesn’t run it starts but that’s it. There’s spark, and i replaced the top or I guess starting fuel injector.
I checked that there was resistance in the injector plug and there was.
Also I removed the hazard fuse and reset the ECU but there was no code?? Hmm??
Either there’s a short somewhere or it not getting fuel.
So any guess?? Please help
Here's my problem
Have you replaced the fuel filter?
I had a similar problem with an 87 Mazda B2000 that sat around for 3 years. I changed the fuel filter and, voila, it started.
Good luck and thx for putting another wagon back on the road.
I yet to do a fuel pressure test.
O also ill spray some carb cleaner down the intake.
Im headed over to work on it here in a fiew.
After a few sprays of carb cleaner it try to run but wasn't getting gas thus broth me to do a fuel pressures test and that was it. NO Pressure!
HA
There's a fun weekend job! since I'm in the mood ill fix the fuel gage in my family's wagon while I'm at it.
Yep got to remove the whole fuel tank to get to it.
But we'll see what came next.
Thanks for your support and helpful suggestions
I guess that the pumps seals dried up because it’s been sitting there for 2 years with a little less then a half a gallon of fuel. it was partially empty.
Once i get some extra $ flowing in i will start my Preformance D15b project. I was also thinking about a swap to a D16z6 then modding that but im a little un shure at this time.
It runs but i blew up or shorted out the Coil pack.
No worrys i getting a new one tomarrow.
Thought i did sux sitting on the side of the highway for two hours!
