i have a 88 honda civic wagon 2wd with the 1.5 and i am having troubles starting it when i try to it floods it and i dont know how to fix it. if you can help plz do.....
are you continually cranking the car, or cycling the fuel pump by turning the key on and off? how do the spark plugs look? i would take one out, leave it plugged into the wire and see if it sparks when you crank the car.
check your dizzy-
It sounds like its starting to fail "IMO"
there can be so much causing "the flooding" but cranking it and stepping on the gas wont help. start with basics- air, fuel, spark.
check your dizzy-
make shure your getting a good spark not a dul orange ohm your injectors posibly one is stuck open they shuold be close to same ohms
Could be a main relay. Which would be the opposite of flooding. Which your car won't do anyway, because it's fuel injected.
Explain 'flooding the throttle body'....
