getting my clutch replaced on my 91 wagon today have ?'s
i wastold to get the rear seals on the tranny replaced since im doing it, about 20 bucks from dealer.
are there any other seals or gaskets i should replace as well?
maybe cv boot that are ont he axle they will be working on? taking it in about 1 hour from now.
cv boot. how many are there? 2 or 4?
rear main seal
and tranny seal.
The rear main seal is the one between the engine and the tranny right? That one should get replaced automatically when you replace the clutch right?
my feelings about it.....WOW!!!!!!
either my oem stock clutch from 91 really sucks or it was really broken. my initial drive was amazing. i dont know if its cause it grips way better or the lighter flywheel really released all the potential power but it launches way better and once in gear it climbs the rpm meter faster. the car only has a very short ram and no other mods.
the shop that installed it for 170.00 with my own brought in parts, did their test run after installing it, said that it is a very strong civic. i noticed it wasnt this strong before the clutch and flywheel. some 96 or 97 civic ex coupe tried to race me tonight as i was cruising home. i have never been able to keep up with anyone civic before. even the DX models would beat me and they were stock. well this one had intake (as i can hear it) and definitly exhaust ( i can see it). well he took on me and i did the same but this time i walked away from him. i was stuned :shock: i guess his girlfreind was kinda shocked cause my civic is totally stock looking too.
final thoughts, get the exedy clutch. it fits like a glove.
get the lighter flywheel, it drives fine as a daily. it doesnt seem to have any issues with starting off or anything. i guess the wieght is really balanced.
the weird thing is that after they finished installing the clutch the car seems to be swirvey. i guess that would be the best way to describe it. it still drives straight but its like it has this tendency to lose control now when i move the wheel quickly on medium speed, like 40mph or so. if i was to turn the steering wheel a bit to the right or left the whole car will lean and keep going in that directions. before that the car would try to return to center again. obviously it has something to do with the reinstall of the bottom part os the car.
i know they had to take off much of the control arms to some sort of support bar that links to the front part of the car. so i wonder do i need another wheel alignment? but my thought is that the car runs very straight on the freeway. another thing i did notice is that the front seems a bit higher. i dont know if its just me or maybe they didnt reinstall the parts correctly down there.
