Want to get a RAGTOP, what to do with roof rack holes?
So, i have an OEM roof rack. the rails are bolted to the car via 3 holes (on both sides).
I have been looking at getting a ragtop, which requires a 31" wide hole to be cut in the roof. with the ragtop canvas installed the complete unit measures 35" wide.. now here is the dilemma! The roof rack rails are spaced about 33 inches apart, so clearly interfere with the ragtop by a solid 2 inches. this requires getting rid of the rails.
Question is, how can I "patch" the existing holes? I know the easy answer is take it to a body shop (which i would need to obviously if i plan on or have to get the rood repainted), but i am trying my best to hold off on that because of, well, $$$.
is this something i could maybe weld myself then grind down? again, bodyshop would be needed for paint.. or would i risk too much doing this? idk
i guess i am already answering my own question in my head, but hell.. toss ideas/suggestions at me!
rubber grommets? lol... ghetto
Once the holes are filled and ground down, all you need to do is get a bit of body filler and fill the dents/imperfections that are left. Then ship it off to the bodyshop and be done!
I've also seen people solder holes if they are small enough holes, and then you can just sand/grind down the solder. If you don't have access to a welder that might be an option.
ha! if they made one just 2 inches narrower, this would work damn near perfect. or, 2 inches wider, then i could just cut out where the holes are
i was thinking last night, as maybe a more temp fix, till i get the car truly ready for a full body "restoration" and paint, that i could use some of those fancy pants fender bolts with a rubber washer? these would sit flat, no? and look semi-decent..
http://i266.photobucket.com/albums/ii25 ... 15-1-1.jpg
but without the hole in it
