fuel pump issue
Madwick
New Wagonist
1990 honda civic wagon dx 2wd
d15b1 automatic
replaced main relay and fuel pump.
i do not have any power to the fuel pump. i connected a jumper from the ignition wire from the radio harness to the (solid yellow, white stripe, single red dot). the fuel pump continues to pump but does not turn off. i am able to get the engine started but i cant seem to figure out why the need for the jumper.
any advice on where to check for a short?
d15b1 automatic
2. Ignition Switch? On back of ignition key cylinder.
3. Or on Main Fuse Panel(under dash) mounted on the backside is the integrated control unit... Part #16
