High speed bogging?
Lately, my rt4wd has been bogging at highway speeds when cold. It recently got to the point where i can't drive up hills or above 50mph. It shakes violently as if it's missing, and will completely skip multiple revolutions at a time if i press the gas down. I've tested the coil, EGR, and advance on the distributor. Any ideas?
When I had this problem, I replaced the distributor, cap, rotor, water pump and timing belt. It ran amazing after. I never realized how little power I had prior because of the miss fire.
its a cheap $20 part to rule out
I'm blown away you won't change a cheap part that will give you better mpg regardless...
I have lost all faith in you.
this...its a dirty cheap part and it takes like ten minutes to replace. You spent all that money on tune up parts when you could have started with the least expensive and gone up....why?
Maybe mention that?
I mentioned it in the post from 22 May 2012, 20:58
I need to quit drinking lol
But in all seriousness, some stuff still could be in there. Some nasties finally made it from your tank.
