toggle menu
civicwagon.com
civicwagon.com
Sign In
Register
Sign In
Register
Sign In
Register
Home
Engine & Drivetrain
Crazy loud squealing from tranny in first and second
Todubbled1
New Wagonist
May 2012
in
Engine & Drivetrain
Just wondering if that would be the throwout bearing in my rt4wd if so how hard is it to replace on these btw its when I push in and let out that the noise comes.
503Wagon
moderator
May 2012
so it only happens when you're NOT pushing the clutch?
Todubbled1
New Wagonist
May 2012
When I push in the clutch and somewhat when I let out.
bam-bam
Council Member
May 2012
Probably is the release bearing, but just buy a complete clutch kit.
REMEMBER, though: the RT has a different TO bearing than any other d-series.
edit: I suspect that the bearing is the same as one for a DA Integra. I had one laying on the bench that matched up, and I
think
that's what it was.
Sign In
or
Register
to comment.
edit: I suspect that the bearing is the same as one for a DA Integra. I had one laying on the bench that matched up, and I think that's what it was.
