Help with passing California smog?
I just cant get her to pass Ca smog. Ive drivin this car all winter and never got pulled over
The car runs great and has a ton of miles. The smog tech claims that my car has so many miles and the carbon buildup in the engine wont let it pass. He told me I should register it in Nevada LOL.. So far Ive gone through the whole cooling system, full tune up, adjusted the valves, timing chain, main relay....and the cat looks newish... Any help on what I should do next would be much appreciated... This is my winter 4x4 so Ill be riding a ten speed untill I can register it or the snow flies.
I have some time and a garage to work... I just really want to smog the car and register it for next winter...
Here are the smog results....
Ideas?
Thanks, and this place has been a wealth of knowledge for me...I dont post much but get a ton of help here Thanks all Lets get this wagon Legal!
Ideas?
Get a 16oz bottle of Sea Foam, enough oil for a change, and an oil filter. first thing in the morning dump one third of the bottle in the crank case and another third in the gas tank, drive it around for 10-20 minutes depending how cold it is where you live and how long it takes for your wagon to get to driving temp. When the wagon is up to driving temp. return home leaving the car running, take off the hose to PCV and while reving the motor slowly pore another third into that hose you removed. this will get the Sea Foam deep into the motor. Get off the throttle and let the wagon idle for a couple of minutes and then turn it off.
Change your oil and filter. Fill up the wagon with 91 and the other bottle of Sea Foam. Schedule a SMOG test, 30 min before the test get on the freeway for 20 min and floor it. This will burn out the carbon build up and get your cat nice and hot. Go to the SMOG and pass your test.
My wagon had over 250k on the motor and had been sitting for over a year and I passed. Also check Youtube for more instructions using Sea Foam.
Good luck.
