Low time, low budget build on a rt4wd. From wreck to clean.
So, bought a 1988 rt4wd wagon for $40 with a snapped timing belt and Presumed scattered head. Bought a new timing belt and after installing it the motor ran great.
Smogged it, paid the $400 late registration fees (knew $40 was too good to be true eh?) and promptly fried the motor due to a bad oil pump.
Anyway, threw and old d15 I had lying around in and due to a cracked radiator blew the head gasket a few days later ( wife needed her car and I got stir crazy so drove the wagon even though I knew I shouldn't have).
I just fixed that and now have a new radiator.
Also fixes that I had done before joining include replacing both driver side doors, replacing the hood, replacing the defroster fan, and replacing the hatch (yes, to that rusty one. The other one had a bad crack right where it bolted to the chassis and didn't shut right.
Good news is, thats the only rust on the whole car).
Also put those rims on and got some tunes going.
You can't really tell, but the passenger front seat is missing as are two of the four headrests, I have them and will be installing them all soon. I have the replacement window for the rear driverside as well as sidemoldings and will probably be having them installed soon.
OK, now you are up to date. Just have the same pictures I put in the intro post, but will be posting more as soon as the weather clears up a little. Next step is to drop in a ZC VTEC engine I recently pulled from a parts car and possibly turbo it (have all the parts-pics soon).
Mission statement- Make this car clean inside and out, and be able to make a good showing of myself at the drag strip. Not going for 12s, but a mid to high 13 would be nice, after all, I plan for it to be my daily driver.
I would also like to incorporate my love of computers into the car and am thinking of settign up some sort of carputer as well as gizmo's and gadgets such as back up camera, voice activated ignition, rfid keyless entry, and cell phone remote ignition.
Those are on the back-burner for now though.
It's a lot of work, but please persevere, it will be worth it, and we will enjoy watching the whole thing!
- Rob
Thinking about attempting my first wire tuck while the motors out, but don't know if I can afford to have my car not running for that long. Especially since I would want to shave and paint the bay at the same time, as well as clean up the motor (not that it's that bad).
Either way I'll keep you up to date.
all of the car side wires are tucked and I've just started on redoing the engine harness. Pics soon (probably Tuesday). Wish I had more
progress for the amount of time it's been since an update, but money has been tight so most of my time goes towards making extra on the
side.
Before washing:
after washing and a little wire rerouting:
More to come later today!
Driver side routing (not done yet):
What's left in the engine bay (going to shorten):
And whats going inside (so far):
Here's the turbo I plan on using:
Shiny new "race" radiator:
Various turbo stuff, will be using a lot of it soon
BBK 62mm TB on a d16y8 manifold (dsm 450cc injectors not fitted atm):
My new bubble window:
And some of my new (and old) toys that are making this go faster and easier:
Gotta have tunes, went too long without them:
It's getting there! I just need to shorten a few wires, decide where the battery is going, and run one or two more wires into the bay. Next is engine harness!
Maybe next summer if I can find the time.
This set up is capable of a lot more boost than the engine is, but should be perfect for the other motor when I get it finished.
Thanks, will do. Good luck with your tuck!
Me either, getting excited. Still have to set up the new engine harness to match the tuck on the chassis then I'll be putting the motor in. Just have to try and not get impatient and start taking shortcuts...
And some pictures of the new wagon. After I get my wagon running, I'm going to brainstorm on which wagon to off-road and which to make clean. Either way, swapping parts back and forth isn't hard and now that I have some experience with the tuck I could do it better. All that for another day however:
Also, some new goodies for my getting cleaner by the day engine bay:
Not really digging the junction here. Think I'm going to try and find some liquid tape or glue to clean it up.
