Confused about PS to Manual conversion
So, I've recently picked up a new baby in the form of an '89 RT beater that promptly had the clutch grenade so hard it took out half the damn case. Well, it's finally out of the shop and in my hands again, but the PS rack is pretty toasty and leaking fluid badly. I've read around a bit and there seem to be conflicting reports about which racks are direct bolt-ups to the wagon sub-frame. Some say the Si hatch (or CRX Si, can't remember) is good to go without any worry, but others have reported that the mounts and sub-frame themselves don't mix and match whatsoever. Is it that the Si and DX racks are sized completely different, etc... or am I just being a complete moron today?
This is a good swap, as long as you don't mind manual steering haha
My problem stems from how I've read conflicting things about how certain manual racks are thinner than the power steering ones and therefore you're left with an improperly fitting manual rack that just bounces and slams around in the larger mount.
viewtopic.php?f=5&t=6784&start=330
I used both rubber isolators at the clamp
EDIT: I.E. I'm just worried about one of the isolators sliding out and then all hell breaking loose.
I believe the rack is bolted down via 2 or 3 bolts (cant remember exactly) on the drivers side and on the passenger side via a D bracket and bush. if the stock Power steering D bracket and bush is too big then use the ones from the non power steering rack. Other than that i dont see why you should have a problem.
