Strange Pinging?
I've recently adjusted the timing on my 87 rt4wd (was about 20 degrees behind) and i noticed that now whenever i push the pedal down a decent amount, a pinging noise is heard. Would this be fixed with a valve adjustment? I'd love to get some feedback. Thanks
Check and adjust cam timing first, then check and adjust ignition timing. One may have been adjusted out of whack to compensate for the other.
