Freek wrote: Well gas gauge is not working in the auto wagon what easiest way to fix this?
Freek wrote: Is the floater attached to the fuel pump?
bam-bam wrote: IIRC the sender/float is accessible from under the seat..
Freek wrote: Not sire of the cluster isn't messed up to. Cause it stays at 1/4 tank I put mine in it today dropped below e
First check wires under the back seat, then change your cluster & then change your Fuel Float sending unit that's in the tank..
