*SOLVED* Intermittent CEL, but no code
I'm running out of things to check, so I'm looking for advice. My car is a 90 CRX Si with a stock B18A swap OBD0 (PR4) and S1 cable tranny.
At constant speed and at low rpm(~2000), I consistently get a check engine light. If I come to a stop, and take off again the light goes out upon accelerating. Also, if I come to a stop and turn the AC on it sometimes goes out. I've checked the LED on the ECU while it was on, and it doesn't blink a code. I always thought the code was stored even if the light goes out, maybe I'm wrong?
In addition to the strange CEL, the engine has problems idling after it has been completely warm and shut off for about 15 minutes. It starts and dies unless I give it a little gas. After holding the gas for a bit, I let it off slowly and it stabilises, but slowly (below 750 rpm). After a few minutes off running it starts to idle normally. I've checked/cleaned and replaced/swapped out FIT valve and IAC valve, but still same problem.
I was able to get a CEL about a week ago; It was code 43 (fuel supply). The screw was loose on the vibration damper (weird nut that seals fuel line to the fuel rail)
and the was a little evidence of gas under the plastic cap. I had a spare, so I replaced it and it seemed to run better, but I still have all the same problems described above.
I thought maybe it's a restricted cat, so I unbolted it and run the engine straight of the header after it was warm. But still same idle issue.
I checked the fuel pressure. 40 psi with no vacuum on pressure regulator and 30 psi with vacuum. I think this is a little low for a b18a, but in spec for a d15/d16. The main relay was replaced not that long ago along with the fuel pump.
I swapped out the MAP sensor and O2 sensor with ones I had lying around and no improvement.
I'm at a loss. Any ideas? Is this a bad ECU?
You could also remove the injectors and take a look at the inlet screens to make sure there isn't debris stuck there also.
How does it drive otherwise after it's warm? Does it misfire or do anything strange? Go over your ignition system thoroughly, especially the distributor cap and rotor. I had a'91 Integra a few months ago I was working on give me a hard time. From a cold start, it started right everytime and ran great. After about 15-20 minutes of driving and the engine got to operating temperature, it would bog...misfire and even stall out if you gave it too much throttle. Even after swapping in working ECU's and distributors, it still had the same problem. The problem ended up being a defective BRAND NEW rotor that the owner had replaced himself. It had a very tiny pinhole at the center of it which allowed the spark to find another path to ground after it was warm enough! Replaced the cap and rotor and all was good again.
Sometimes over looking the simple things wastes a lot of time.
After it's warm it still drives fine. Although I do remember a while back having some hesitation after giving it gas. This falls in line with a bad or incorrect fuel pressure regulator. Also, the idle seems to get slightly weak. When I run the AC or the radiator fans come on the idle takes more of hit than I would consider normal. I'll try a new fuel regulator since this is the only part that controls the pressure. The fuel pump is the same for both cars.
I'll work on getting the fuel pressure in spec and go from there. It could be something really simple like a rotor.
