replacement motor do i need to switch oil pans?
hello everybody, so long story short ive done the research and everything says i need to replace the oil pan from the 4wd stock motor everytime i swap a new motor in?
i dont remember having to do this before, im swaping my motor in now and i feel like im having clearance issues sliding the transmission on the motor. but i am also very sick right now and just kinda irritable and dont want to do much of anything so i might not be trying hard enough..
is there any easy way someone can reccomend to as how to slide the transmission on the motor easier , i used the allignment tool and it lines uip straight still too.
I had a fear of this, they took the old oil pan when i got my new motor because the old ZC was blown up, i had a rod go thru the oil pan so i didnt think twice about it.
i keep having motors blow is it because of this oil pickup you speak of? i keep shitting piston rings out my exhaust lol
its a JDM SOHC ZC THANKS FOR THE QUICK FEEDBACK YOU GUYS ALWAYS COME THRU!
but because i havent swapped the oil thing will this cause premature wear on piston rings and be the reason for the continuous 2 year headache battle?
HCW 4Life!
You'll need to extend the wires from the back of the block to the thermostat housing and update the plug.
anybody else wanna chime in with insight @charb where'd you go?! lol
i guess all wagon pans are interchangeable
whats the deal with the oil sump though? whats it do? am i not going to be alright with a sohc zc someone said yes someone said no
This is for the fan switch. if its not hooked up the fan wont run and the car can overheat when you sit in traffic or the drive thru on hot days
The obd0 88-91 civic engine have this switch on the back of the engine block by the oil filter. You need to extend the 2 wires in the pic below and attach a 2 connector plug from another harness so it can plug in by the thermostat. These two wires may be hiding inside a black rubber boot on your stock engine harness.
