No start :/
The previous owner of my car said that there is a newer head on the car, and when I put it on today I realized I didn't keep the old spark plugs. The ones I got for the original d15 didn't connect with the spark plug wires. How can I find out what plugs to use for the head I have?
Thanks
Thanks
Ones in my ITR have been in there for at least 5years, could even be original and there is nothing wrong with them.
there just cheap ngk copper plugs. figure they're good for 10k. but my car is always happy with a new set of plugs. so why not? i also change my trans fluid every other oil change. call it ocd, i guess.
That would make sense to post up what kind of head it is lol, I made a post on d-series.org and they think its a y7 head. I know it's possible to do this, but I think my engine is still dpfi. From what I've read that is a pretty useless swap without converting to mpfi, because there would be no gain. I'm just going to assume that the original head went bad somehow and the PO put this on because he had it or got it for cheap. Here are the casting numbers on the head: P2F-7, B2E-HA-7, D7B05124BD. There were also four circles with two numbers on each which were from left to right: 02, 24, 01, 97.
I have a problem with the engine. I got the head back from the machine shop for replacing two bent valves. I got everything put back together exactly the way it came off. The timing is correct and the wires are connected correctly I believe (on the head 4-3-2-1, and distributor:
3-4
1-2)
On the other site they think that the distributor is off by 180*, which is making it not start. But the rotor on the dizzy has the number 1 for cyl1 up, which it should be when at TDC. Do I need to take the rotor off and rotate it 180* and install it back on the dizzy then rotate the dizzy 180* and install again?
Thanks guys
If my distributor is off by 180, that would have the rotor with the 1 pointing down, will that still be correct?
EDIT: Spark plugs are the same, so that is not it. I tried it again after putting the plugs in, and it kinda tries to start like spitting and sputtering but never a start, the key has to be constantly turned. I don't know what else to check since it isn't the plugs, it is getting gas, and the distributor is fairly new so that should be fine. PLEASE HELP! I really need the car to be running, what else can I check?
Yes, it was running before I took it apart. I don't know if I have good compression because I don't have a tester, and how would I check for spark and fuel?
As you can tell, the valve on the right is taller than the one on the left. The two bad ones is the right exhaust valve on the number 1 cylinder and the right exhaust valve on the number 3 cylinder
And it's a good thing my roommate is on spring break haha
Sorry the pictures are so blurry lol
