integra break upgrade super cheap and easy
i bought the full suspension off a DA integra for $70 got the front rotors turned for a pizza and of course new pads. the swap is straight up u can use your original civic brake lines. I also have the integra PP valve and rear suspension still to put on but even just the front for now are a lot better than before im only like $100 into the whole project so far and its been worth every penny.
Is your wagon AWD? What year?
But, bigger front brakes FTW!!!
it says it here too on this site, http://www.angelfire.com/az3/hondawagon/brakes.html "I don't recommend this converstion to anyone"
the author of that site mentioned that its a lot of banging the metal to make things fit, mrwagovan says that its metal and fab work in order for things to get in. if you're gonna attack this, call him first.
Thanks SI, I've read about that type of upgrade. It sounds like Turbo_teg is sayin the teg brakes are a direct bolt on(no need for re-drilling Prelude rotors
