Question about D-series heads, interchange?
OK I am doing a head gasket on a D15B2, and the head looks like trash, the mating surface is pitted to hell. Machine shop said they may or may not be able to machine it out...
I have 2 other heads laying around, but I am unsure of which I am going to go with.
Option 1: D16A6 head, looks really good, but has stripped out spark plug threads on one cylinder. Looks like it can be repaired, just waiting to find the auto PM6 ecu to complete the MPFI swap. Would it even be feasible to run the A6 head with the DPFI setup? Its my daily driver, so it doesn't necessarily have to be fast, just has to be done right.
Option 2: D15B7 head, from a 93 Civic DX. Has one burned up valve that needs to be replaced. Of course, I can use valves out of the B2 or the A6, IF they interchange. I THINK this head is basically the same as the B2 head, but I don't know for sure. Anyone?
Also, with either of these heads, would I use the stock B2 timing belt, and would I just use the cam gear that came on the dead, or do I need to swap in the B2 cam gear.
Thanks!
Thanks!
Not positive on the A6 head but I think they are the same as well. Look at the marking stamped on the front of the heads. If I recall they are PM3-(casting number)
Oh and the cams.
I think what I'm gonna do for now is take my B7 head to the machine shop, have it resurfaced, have them swap in a good valve from the B2, and slap it on there as is for now. Maybe I'll do the MPFI setup while I'm at it, maybe not. Then a little further down the road I may swap in the A6 cam.
I was reading here that someone with experience said putting the A6 head / Z6 manifold combo on a B7 with auto trans actually made the car SLOWER, and hurt the gas mileage significantly. Kinda unsure now about if I wanna try it, but I figure, if its a no go, I can just swap the old cam right back in.
