Are Shoulder Seat Belts Suppose to LOCK?
My shoulder seat belts on my wagon do not lock.
They retract up and down but do not lock in place if you were to brake hard.
I brought it to the honda dealership today for them to look at and the tech said they are not meant to lock?!
Can't imagine this being the case so I told them that can't be and they are looking into it more for me.
So are they mean to lock or not??
The dealership had the lead tech take a look at them and took it on a road test and got them to lock up when braking. Guess mine are less sensitive then others which is kinda scary.
Also, what did brand new shoulder belts cost you from the dealership?
I should really test them I have yet to actually slam the brakes to test them out.
They said the lead tech who I spoke with tested them himself with a passenger.
Both locked up as they were suppose to.
I think I'll test them soon and mash on the brakes at high speed and see of I can get them to lock up.
Yes Honda does have a lifetime warranty but it seams sometimes it's a bit difficult to get the dealer to actually follow through with it.
Maybe I should take it to a second dealer and see what their results are.
I wish I had manual ones would make finding seat swap a lot easier!!
How difficult was it to weld them did you add any xtra bracing or just weld them straight on??
http://honda-tech.com/showthread.php?t=2972687&page=13
What seems to be happening is your inertia locks aren't working as well or at all anymore. This can happen for lots of reasons but most often is from a lack of lubrication. My local dealer simply sprayed some silicone spray on the locking mechanisms and voila, my belts were working 100% as if from the factory again.
Another upside is that now when I take my belts off they retract back into the pillars as if new.
EDIT!: A big problem is that Honda has superseded the part number for the seat belts a bevy of times (at least 5-10) in the past 20 years and at them moment the only one available is discontinued and awaiting a new superseded part.
I just looked into this again about a week ago (last time was for my Wagovan in July of last year) for my new RT wagon so just see if your dealer will inspect, clean and lubricate your belt mechanisms (they're not legally allowed to tinker with them internally) and hopefully it solves your problems.
