91 4sp manual could use some help on some things
I have a few questions on some things.
1) I need to replace my front transmission mount and was told it is easy to replace just need to unbolt it and jack up the car a bit to get to the bottom bolt and swap out the new mount?
2) I also need to replace the rear struts BAD! I plan to use Monroe struts part #71238.
I was told I could just jack up the back and swap out the old with the new ones and do not need a spring compressor to do it?
(Believe the back springs are cut) I have never done this before but figured it shouldn't be to difficult.
Any suggestions or advice is greatly appreciated!
2. You'll need to compress the springs unless yours are cut down or really sagged. To check that jack up the car and let the wheel sag and see if you can move the spring around.
My springs are cut just not sure how much.
I replaced the existing blown struts with monroe struts #71238 and kept the rear springs which are cut with coil over sleeves.
The bottom perch seamed to be a bit loose on the sleeves compared to the old struts I am assuming this should not be an issue as I have seen some people grind this off.......?
Also after taking off the old struts I see there are no bump stops not sure if there is suppose to be any on there??
