recovering the vinyl part of the door panels
I searched the forums and found a fair amount of info on re-covering headliners and also the fabric part of the door panels, but nothing about re-covering the vinyl part. I imagine that it would be difficult to do because of the contours. Has anybody had any success with this?
My door panels all have several large gouges in them and I was wondering if anybody has any suggestions and what I could to do to make it look "prettier." I tried one of those vinyl repair kits, and that turned out to make things worse in my opinion. Has anybody tried anything creative like peeling off the vinyl and painting the bare door panel? Or perhaps re-covering it with a different type of material? Any suggestions would be much appreciated.
The guy separated the upper & lower panel pieces. Probably either drilled out or used a solder iron to melt the plastic rivets that are used to join the two parts together. Removed the old vinyl & draped/placed new vinyl on the panel & then just stapled new vinyl to the backside flanges of the panel. He probably used some contact cement around the door handle opening.
Turned out ok.
When I saw the end result I thought, hmmm. I guess I could have done that but it was my son's car so .... get off the game console and work on your car! You can buy fabric at a local fabric store or online from places like jc whitney.... I would not be afraid to try that now. What is the worst that could happen? You see this done on the tv shows all the time. Learn by doing?
Had not considered the use of a heat gun but sounds reasonable.
