1987 wagon or wagovan, what the differenced?
I have been working on a 87 Honda wagon/wagovan?, Good grief every autoparts store gives me a different number for the drivers side cv axel, First I was told by the owner it was a wagovan, so I ordered a shaft for the wagovan, well it was 35+inches long and the one I needed was between 22 and 23 inches (it is so worn out it's hard to get exact) so I sent that back and they sold me another one but the spline count didn't match. This has got to be a real headache. please advise if you know, Thanks
is your wagon 4wd or 2wd because that is the biggest issue. my wagon is an 86 2wd and i always just look for the 1.5l CvCC 2bbl carb civic base model when searching parts. if its 2wd , most engine parts are interchangeable with the 1.5l carb'd civics. i was about to replace mine, and the civic and the wagon / wagovan were showing the same part number. i haven't actually gotten them to compare though.
the only parts that ive encountered that were wagon specific were the headlights/corners/tail lights, everything on the dash, gas tank and trim pieces.
redpepperracing.com has a lot of info on the 3g civics like this : http://www.redpepperracing.com/forums/index.php?showtopic=20738
hope this helps
