i'm thinking of swapping in a sohc zc..question will the si harness work on the waggy????i know i'll need the ecu..just curious bout the harness...any help is greatful thanks.... 8) :twisted:
If your wagon is already MPFI you won't have any problems just dropping the motor in and pluging the ECU. The only thing that you might need to do is rewire the distributor.
If your wagon is a DPFI, you will need to do the DPFI to MPFI conversion then rewire the dizzy. Theres lots of "DIY and How To's" on the net. A great place to find out different conversions is http://www.honda-tech.com.
If you have any questions, or anymore help, I might be able to.
is your wagon a rt4wd model or a 2wd? If its a rt4wd then the harnes is plug n play. I swapped my RT with a sohc ZC when i got it cuz the motor was blown. :idea:
If your ZC is complete with the injectors and fuel rail all you would need is the parts I have above do the wiring and a ECU.
