Hey guys.. I'm doing my 91 integra brake upgrade Thursday and was wondering if all the GOODRIDGE steel braided brake lines are the same..? Does it matter if it Acura or Honda..?
Not all are the same. Our vehicles have drum brakes in the rear and use different lines over the rear disc set up. I'm using DA integra front lines no problem. You would need to use the integra kit for all 4 corners if you are doing a rear disc conversion.
Okay kool.. I just picked up a pair of 92-95 ex front disc brake setup.. Its exactly like the integra DA.. Im about to order some brake lines rt now.. So excited.
Good luck with the brake swap! I just ordered a set of 1990 integra lines and we'll see how these puppies feel. I was just trying to figure out if in the rear they replace the whole line from the rear caliper to the body or if it's a partial.
Off topic but it sounds like you are putting eg brakes on a ef/da? If so that isn't going to work very well, knuckles are very different.
On the brake lines, I went through the same thing on my brake swap. For the most part all factory disc hondas use the same brake lines, just different lengths.
I wouldn't recommend. Your geometry will be off IE(massive amounts of negative caster and positive camber) If you still want to run them you will need a camber kit, depending on how low you are other issues may apply.
Stick with DA or EF EX knuckles/brakes.
Note, DC are the same as what you claim to have 92-95 civic ex
liper
I hope so. I want to test the prototype on Fool's Gold!
