Has anyone used rust converter before?
So I have a wagovan I'm trying to fix the body on. Its a project/experiment. I'm on a budget and not to mention lacking when it comes to resources, which is why I joined this site.
Now to the real question, have any of you ever used a rust converter. I figured this would be healthy alternative to cutting and welding, granted its done right. Not to mention its about 7 bucks for a can of it. Any advice and help would be appreciated. Thanks
But ultimately your car will rust again, so you may wanna go to harbor freight and pick up an $80 flux core welder, then go to home depot or lowes and get lincoln flux core wire...the HF stuff throws slag everywhere, and you end up grinding more than you weld, and you will be covered in burns.
Do it!
the key to a quality primer/paint job that most people mess up on is that primer should not be exposed to weather for extended amounts of time, like when projects are in limbo. primer needs to be sealed properly to be exposed for periods of time or painted over. If you simply use regular primer and drive around in wet weather it will rust under neath through the primer even if you cant see it. oh and save your elbow and buy quality light weight filler that can also be used as a glazing putty.
