Getting transmission attached Help
I have been fighting this to exaustion what am I doing wrong? I did a re-alignment of my clutch to make sure. How do you attach a manual transmision back to an engine. I will post a pic when I get home.
A lot of wiggling and spinning the crank have worked for me in the past. Just be sure you used the clutch alignment tool when installing the pressure plate. Pull the starter off too if not already.
Spline count differs between years...
** im sure you know ** but it looks like you have a bolt in the trans going the wrong way in that picture.
Thanks everyone. We ended up getting it pretty close and put some bolts in. Then with the hoist we tiped everything vertical and set the engine on the transmission with a little wiggle it slipped right into place.
