Anyone ever had a 1 piece driveline made?
i remember hearing about someone who had a 1 piece driveline made i was wondering who that was and if they had the specs on the driveline. im talking to a few driveline shops about making me one and one suggested getting the specs and parts used from someone who has done it so it would makes thing easier and cheaper!!!
It was HondaWagonSTS that did it, he used it for AutoX.
The thing is... do you really want to do this? On dry pavement i can pretty much garentee you'll crack a diff or something similar.
You can see the weld at the shaft and the viscous coupler.
The reason I did this was the coupling was leaking and I had no 4x4 just front wheel drive. No problems so far. A custom driveshaft would weigh a lot less. That coupling is pretty heavy.
At least there should be a intermediate support bearing to split the lenght...
Imagine the harmonic vibrations for a sec on 6 foot long prop shaft???
IMHO there should be 2 props....
Cheers!
since your one piece driveline, did you actually fab a lever to disengage/engage the 4wd? howd you do it? pics please.
thanks
wagon.......................4ever......................
