swap help
so, I've never done a swap before in my life, and decided to TRY and pull my motor out the top of the car, but i didnt take the tranny with it, and now everything is kinda stuck, and it looks like my only option is to undo my tranny mounts, and let the tranny fall while my motor is still hoisted,
anyone got any ideas?
or anyone in washington willing to come help me?
Do you have the axles out, transmission loose? I think you'll at least need to let the end of the tranny angle down. I've pulled many of these engines, but always WITH the tranny attached.
Put the car on stands, put the jack under the trans then unbolt it- its not on the ground and you can wiggle it.
should be able to pull the motor after.
To be honest its so easy just to pull it all at once then pop the trans on the new motor and put it back in. To break them apart and pull just the motor is a pain in the rear "my opinion, not everyones"
i just cant wait to get my wagon running,
Id try to get a few bolts in the trans and pull both out together. So much easier.
