what to do??***(hit my traction bar)***
hey guys i ran into a problem and would like to get some of your opinions on how to approach fixing my issue...first off let me say i didnt do this, my brother hit my car when i let him borrow it. my car was at the lowest setting that my coilovers would let me go so it was pretty low and he didnt slow down enough and hit some railroad tracks...ok on to the pics
as you can see the frame is supposed to be parallel with the ground...which its clearly not...im just planning on putting back the stock crossmember and radiator but my question is what is the best approach to straighten the frame rail back so i can mount my crossmember....i have no bodywork experience which is why i ask...should i just take it to a body shop??...if so how much am i looking at??
thanks again for the help
At this point it looks like strictly a body shop/frame repair shop matter. The nut that goes welded behind the frame looks to be tearing out as well. I don't think even the stock crossmember will bolt on anymore.
Try taking it to a local reputable body shop for a free estimate on what the repairs will cost. The good news is that I've seen worse damage repaired successfully. I recommend the Full-Race traction bar after you repair the damage. It sits much higher and is a pretty solid unit. Good luck.
