Block off plate hole.updated with pics
Not sure if this has been covered I searched but not real sure if I am calling it the right thing.? Ok, on the right side of the steering wheel where accessory switches go (the bigger one) someone had cut it to put in an oil gauge. That's what I was told. Anyway so my dilemma is the lip isn't there so switches or even the block off cover wont clip in. Anyone have or fixed this before? Thanks in advance, I will get a pic tomorrow to better show what I am talking about.
They come in black so you'll need to paint it.
With a little heat you can make an elbow.
My 2cents.
Good luck.
Ask a professional. They'll make it look clean.
Dont you hate cleaning up other peopels messes
just cut the very bottom piece, make the cuts tight and the new piece fit tight so there are no gaps- should turn out clean and look better than the gouged out look.
Its really hard to explain- but look at the 1st pic, the piece you need to cut and glue in is like the size of a toothpick bottom left corner to bottom right corner.
