1991 Wagon 4WD Distributor Cap Rotor SCREW falling out...
Howdy all.
I've got a 1991 wagon 4wd. it's got about 170k on it and purrs. Back in May I made a drive of about 800miles after already having the car for 10k(and running fine). I broke down on the road and found it was my distributor cap rotor that was the problem. More specifically, the screw holding the rotor to the engine fell out/broke off. I replaced the entire rotor and screw and the problem was solved until about a month ago on a short drive. It happened again. I sent it to a mechanic since I had no time to worry about it and he discovered the same problem of course. This time, he replaced the whole thing+screw and also dipped the screw in locktite to keep it stuck in there. I picked it up and drove about 50mi before it popped right out again! Took the cap off, and screwed it back in and took it to a safe place.
not sure how to solve this.... is it just a problem with the screw or is there some larger problem causing the screw to wiggle out frequently? any ideas or experience would help a lot, as this is a pretty small/hard place to work on if this is going to be a frequent problem....
Thanks!
Thanks!
guys from the ecefc helped me figure out what was wrong and said its a known issue .. :roll:
Also, note that the hole in the shaft is not tapped all the way thru, so the right screw won't start from the wrong side.
Craig
A 1 drop of blue loctite to the screw threads.
Tends to help out.
Don't Use red or you will never get if off.
x2.... Never forget the first time an EF left me on the side of the road many years ago because of that f***** screw.
