D16Z6 swapped wagon, randomly shuts off while running
Figured I'd make a thread for this while I work through it, just in case anyone else ever has the problem.
Runs and drives great most of the time. revs up, doesn't run rich or anything. perfect.
Randomly however, she will just shut off on me. Tach drops to zero, foot down and no go. Seems like no spark. Tach remains at zero even though the engine is physically spinning (Still in gear with clutch engaged). Happened to me twice this afternoon, and hitting the ignition seems to "wake it up" so to say. Tach jumps back to rpm, and I get spark again.
Most seem to say this is the ignition switch, but my switch is brand new. (Since whenever that means anything. Great parts quality these days) Dizzy is new, but I think its problematic as well. Cap and rotor new. plug wires new, plugs new. etc.
Anyways, if anyone has some insight to throw my way about this issue, I'd appreciate it. If not, I'll update with the solution when I finally trace it down.
Ignition upgrade
Well, I got mad that I had to pull the intake mani to do it (To make it easy, I know I could have snaked it out around the intake piping)
So now my entire car is apart and I'm bolting turbo parts on.
Moral of the story though, get a volt meter and check your battery voltage and make sure your alternator is charging. My car was basically running out of electricity on the road.
But yeah, I went through all the things you guys mentioned. I actually seriously beefed up the thermostat housing ground when I put the motor in, and checked it to make sure. It's fine there. Checked the plugs on the tach, checked the dizzy, etc.
Finally got in my car to go for a drive to see if I could get her to die on me. Shut my door and my autobelt kicked back, and my tach shut off with the autobelt running. After my belt secured, my tach came back. Headlights, same story. Alternator was also getting crazy hot, and shortly after this my car shut off because it overheated.
