Engine noise, Low RPMS
I am purchasing a vehicle in the next week or so in another state, (620 miles away to be exact).
The guy posted up:
"The flaw of the vehicle is that it does make minimal clicking noise in the engine at low RPM's so it may need little engine work. I personally do not think that it is anything too bad because it starts up everytime, drives absolutely fine & does not smoke at all."
I personally don't know if this enough information, or what the possible issue could be since I can't physically be there, so I want to know if this trip is worth while, or fixable.
Thank you.
The guy posted up:
Thank you.
There is an outside chance it could be piston slap or gudgeon pin noise, both of which indicate more serious repairs might be soon required. The latter two are more of a knock or deep rattle than a tappy rattle. To much spark can also cause a rattle.
A noise described as clicking is almost always tappets.
