Reverse lights = instruments work?
Swapped my DX transmission to a civic SI transmission (thanks 1988rt.)
But now the only way my tach/check engine/seatbelt clock and such work is with the transmission in reverse?
When i first started it up i dont believe it did it.
What should i check?
The 02 sensor plug fell off and i used a butt connector to connect that back up but im not 100% sure its the right wire.
also the little single wire plug/sensor under the distributor plug fell off and idk what to do about it, its just loose.
  • TheGmanTheGman Wagonist
    Just kidding it was just a fuse, always gotta check the simple stuff it seems.
