Crx hybrid dash swap, Integra gauge cluster & 3 gauge po
I finally had time to snap some new pics of my dash. I did this swap like a year or two ago...now if anyone asks the Crx dash does NOT fit directly into the wagon. You literally have to cut the top half of the wagon dash off & attach it to the bottom half of the Crx dash.
Plus, I thought it wasn't enough to leave the stock gauge cluster in so I found a 90-93 teg gauge cluster & swapped that in too. I added the white face gauges before I put it in. YES they're GLOW GAUGES.... :x
AND if that wasn't enough I added a triple gauge cluster in the center of the dash - YES more GLOW GAUGES :roll:
If u look at Akiraboy's pics you'll see where the gray section(upper section)meets the Blk.CRX dash.
:arrow: When I was at the Junkyard.I installed a CRX dash into a Civic Wagon .The CRX complete dash fit perfectly into the Wagon w/o hacking the upper section. 8) My hats off to Akiraboy for a job well done.I even saw a complete RSX dash installed into a EF.I never did the swap(CRX to Wagon).It was too much work.A hundred screws,clips,tie straps & brkts.CRX dash does look way nicer. 8)
ok besides cutting that section off. Does the rest of the dash bolt up?
but all the screws and what not mount jsut fine?
At least he searched!
someone tell me which part of wagon dash is top half that need to be chop off?
Read my postings above.The CRX dash fits W/O cutting the upper half.
wagon............4ever....................
