d15 bottem end VS d16 bottom end.....
what makes a d15 a d15? is it a smaller piston bores? stroke? im asking because my buddy is offering me a free d15 and i want to use the bottom end to make my mini me. my plan was to get shot peened d16 rods w/ ARP bolts, and vittara pistons but will the d15 crank let me do this?
however, as far as i know, the D16 rods will work with a D15 block and crank using Vitara pistons. this is due to the Vitara's lower compression height and huge dish.
are you going turbo or N/A?
compression with the Vitaras and a Y8 head would be about golden in a D16... 8.6 or so.
am I high or does that look correct?
edit: nvm: 10.6:1
This is what I have, its a nice jump from stock a6 as long as you do a real vtec with ecu, not an RPM switch.
I bought mine with the RPM switch and my buddy loaned me a vtec ecu and a conversion harness to try for a day and it was nice
