Seat Belt Warranty
From the NHTSA
Make / Models : Model/Build Years:
ACURA / INTEGRA 1986-1991
ACURA / LEGEND 1986-1990
ACURA / NSX 1991
HONDA / ACCORD 1986-1991
HONDA / CIVIC 1986-1991
HONDA / PRELUDE 1986-1991
Recall Number: 95V103001
Summary:
THE FRONT SAFETY BELT BUCKLE RELEASE BUTTONS CAN BREAK. THESE RED PLASTIC RELEASE BUTTONS ARE MARKED "PRESS." IF A BUTTON BREAKS, PIECES CAN FALL INTO THE BUCKLE ASSEMBLY CAUSING THE BUCKLE TO OPERATE IMPROPERLY.
Consequence:
THE SAFETY BELTS WOULD NOT PROVIDE ADEQUATE PROTECTION TO AN OCCUPANT IN A VEHICLE CRASH.
Remedy:
OWNERS SHOULD PROMPTLY CHECK THE CONDITION AND OPERATION OF BOTH FRONT SAFETY BELT BUCKLES. CAREFULLY INSPECT THE RED RELEASE BUTTON FOR ANY BREAKS OR CRACKS. CHECK THAT BOTH BUCKLES ARE OPERATING PROPERLY BY INSERTING EACH LATCH PLATE INTO ITS BUCKLE, TUG ON THE BELT TO MAKE SURE THE LATCH IS SECURELY LOCKED, THEN PRESS THE RELEASE BUTTON. THE LATCH PLATE SHOULD POP OUT OF THE BUCKLE WHEN THE BUTTON IS PRESSED. IF EITHER RELEASE BUTTON SHOWS ANY SIGN OF BREAKAGE OR CRACKING, OR IF EITHER BUCKLE FAILS TO OPERATE PROPERLY, PROMPTLY CONTACT YOUR AUTHORIZED HONDA/ACURA DEALER TO SCHEDULE AN APPOINTMENT TO HAVE THE BUCKLE REPLACED OR REPAIRED, FREE OF CHARGE. THE MANUFACTURER IS DEVELOPING A REMEDY DESIGNED TO PREVENT THE FAILURE OF THE BUTTONS THAT ARE NOT CURRENTLY BROKEN.
Notes:
SYSTEM: INTERIOR; SEAT BELTS; BELT BUCKLES. VEHICLE DESCRIPTION: 2-DOOR, 4-DOOR AND 5-DOOR PASSENGER VEHICLES EQUIPPED WITH SAFETY BELTS MADE BY TAKATA CORPORATION. NOTE: IF YOUR VEHICLE IS PRESENTED TO AN AUTHORIZED DEALER AT AN AGREED UPON SERVICE DATE AND THE REMEDY IS NOT PROVIDED FREE OF CHARGE WITHIN A REASONABLETIME, PLEASE CONTACT HONDA/ACURA AT 1-800-999-1009. ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S AUTO SAFETY HOTLINE AT 1-800-424-9393.
ACURA / NSX 1991
Summary:
Consequence:
Remedy:
Notes:
Just to clear the air....
I'm a dealer tech. And no one probably knows more about the engineering of our cars than the engineers and me.
The seat belt is warrantied for the life of the vehicle as long as :
1: it is not tampered with
2: it is defective
3: it is not damaged from a wreck.
now of course it is up to the dealer's descresion is to if they may warranty the part based on the complaint. You see, we at the dealership get customers with some really fu*ked up problems. Here are a few examples:
One window rolling up 0.5 seconds slower than the other.
Check engine light on with the engine running crapy. you know, the infamous Integra tear-R punks with the 5th gear to second gear downshift.
power seat switch panel on a 3.5RL broken. (owner weighs in at 275 lbs.)
Side airbag light on when the cell phone is on the passenger front seat.
A tiny squeak from the trunk while driving 60 mph over a bumpy road.
The seat belt motor and/or rail is covered. And so is the lap and shoulder belt retractors. The wiring and the door switch are not! So ifyour belt has normal wear and tear from usage then they may not cover it.
So if the tech finds any thing else aside from the normal warrantiable items then Acura motor division will not pay the dealership for the repairs and you will need to.
Its no different from going to the doctor. Except doctors will always PRACTICE for the rest of their lives and the dealership technicians actually fix the problem.
Its all about the attitude. They are a place of business just like any one else. If they see someone who doesn't co-operate and is always giving them an ugly eye. Then why should they need to bend over backwards?
