where to get a carb. brown top zc?
if someone could let me know where i can get one of these motors for a reasonable price, ive asked several motor places about them and none of them carry it. gomotors said they get them but only once in a while.
but there was a guy sellin a rebuilt 86-89 teg motor either in Wis or in Minn
Davens had a carb kit
It took awhile to find though. I think more places have them, but the idiots answering the phones don't know any better. I think I talked with a dozen places.
Here's the typical conversation:
Them: 'ello
Me: Yes, I'm looking for an engine for my car...but its kind of rare.
Them: Okay, whatcha lookin for?
Me: It's a Honda dohc ZC but-
Them: Yeah we gots 'em. They're $xxx.
Me: I need it to be the earlier browntop ZC and-
Them: Hold on, lemme check...Yeah we gots 'em. Browntops.
Me: It also has to be carb'd. The came as a dual side-
Them: These jdm engines ain't CARB approved
Me: *sigh* Yes I know. It needs to be carbureted. It came as a either a single downdraft or dual sidedraft. I'll take either at this point.
Them:-
Me: Hello?
Them: There's no such thing
or
Them: We gots sohc zc that have carbs. That it?
Me: No, there is a browntop dohc zc that came carb'd. It was available in the Honda Quint around 1985-86. If you don't have one, what are the chances of special ordering one?
Them: *click*
So keep looking...the alternative is to get a usdm D16a1 or browntop ZC and buy a Weber carb kit for it. That's what I ended up doing anyway.
Can't you use the 84-87 injected brown top zc with D16A1 carb manifold and dual DCOE 40/45's? I think the dizzy would need to change as well..
The blacktop is electronic advance and requires the ecu and mpfi.
Your other options:
JDM fuel injected browntop ZC + Weber kit
USDM 86-87 browntop D16a1 + Weber kit
A good place to find D16a1 stuff cheap is the gen 1 teg group: http://www.g1teg.org/phpbb/
Also, I'm actually considering doing a conversion from carbs to fuel injection. If I do this, my browntop carb manifold and Weber will be for sale.
I only ask because you never want to be someones guinea pig and since our platform enjoys little to no aftermarket support, most places don't know much about them.
I'm not telling you what to do...but I'd clarify a few things with the shop before taking the plunge.
1. The newer D-series engines do not bolt into the pre 88 chassis. The main reason this is problematic is that the wagon tranny won't bolt to the d15b engine. So they use the d15b hydro tranny, which means all the mounts will need attention. We're talking engine mount fabrication(no one makes kit that I'm aware of). These custom mounts will probably involve hard welding, making your plans for a B-series swap later (which there are bolt in mount kits) a lot harder since all four stock locations have been modified. And while it may sound like your wagon will be converted to run any hydro type transmission, its not. Its still a cable actuated, just with an adaptor assembly that actuates the hydro parts. And I'm not 100% sure that adaptor can be transplanted between a D-series and B-series engine.
2. The wiring is not like your typical engine swap wiring (moving pins, adding wires etc). Its even more work than a DPFI to MPFI swap. You'll need to install several obd-1 parts - like sensor assemblies, fuse box, speedo assembly etc that didn't come in the wagon. This is both a lot or work and money. The best route for doing this usually involves a whole parts donor car. I wonder if they have factored this into their price quote?
3. The entire fuel system basically has to be replaced. There is some debate as to reusing anything from the old system because its designed for 5-6 psi, not 40-60psi like on fuel injected apps. And this is particularly important because any fuel "issues" have a strong likely hood of turning into a car consuming fire. Make sure they know exactly what they are doing.
4. With all this custom work, get a concrete timeframe for completion with some accountability for delays. Its not unusual for a hard swap or problem to get pushed to the side of a shop while they figure stuff out...then other jobs come in and their focus gets sidetracked. Days turn to weeks, weeks into months. This is especially true for swaps that they quoted too little $ on for the amount of labor involved.
6. This last point is more of a personal opinion, so take it with a grain of salt.
The d15b is somewhat of a darkhorse in the swap world. People run it because (A.) its about the least expensive jdm engine available and (B.) its rated at a very competitive sounding peak 130hp. My problem with the vtec d15b is that its even more gutless before vtec then the more typical d16z6. If you want to go anywhere, you need to rev up into vtec...which hits hard, but only being able to develop that 130hp in a very narrow, peaky range is kind of annoying.
Now don't get me wrong...Fuel injection, a workable ecu and the potential for easier future upgrades have their appeal. To get these features and be a little less work, I would actually recommend an 88-89 blacktop D16a1. You'll still have to deal with points 2 and 3 (and 4 really applies to any shop swap) but at least it bolts in and will have a much fatter, useable torque curve. You'll give up a little at the very top of rpm band but you won't have to go there all the time to get anywhere. With the blacktop D16a1, you'll have converted to obd-0 and can run either a pg7, pm7 or even a pm6 ecu. And an obd-0 to obd-1 conversion is mostly just wiring related and can be handled with a simple conversion harness wheever you're ready.
Whatever you decide, stay on top of the shop. Get the answers/explanations and make sure they're not promising more than they can deliver.
1)It's a straight drop in:D
2)NO Wiring and NO complete fuel system overhaul:D:D
3)The 88-89 only has only 5 more hp than the 86-87
4)Lots of speed parts for the 86-87(for the 88-89 too).
5)The 86-87 D16A1 is virtually identical to the "brown top ZC" that blessed the 1st Generation JDM CRX Si.and the only DOHC D series engine to ever make it to the US. :twisted: :twisted:
>>Physically speaking...True
>>The 86-87 D16a1 was fuel injected. He either has to find a replacement carb system or convert to fuel injection...which is still a lot of wiring/fuel system modifications
>>Yes, but the 86-87 ecu is not chippable while the 88-89 can run a chipped PM6 and making it much easier to convert to obd-1 at a later date.
>>I don't know about lots, but sufficient
>>I don't know why, but one was rated a 113hp and the other at 133hp. Something is different.
On a forum over here they took one of each motor, stripped them down and compared them.. alot of the parts are interchangable but thats about where the similarity ends...
http://muller.net/sonny/crx/
Check out another 1 of our lost members 87 Wagon(rwpq). :twisted: :twisted: With a D16A1 @ this link:
http://p196.ezboard.com/fhondacivicwago ... D=14.topic
More pics of rwpq's wagon:
http://p196.ezboard.com/fhondacivicwago ... D=17.topic
