help!! no acceleration going to the motor
this problem started when i came back from work on the freeway i heard a poping noise and the check engine light turned on then it started losing power so i step on the acceleration and the car would just bog. so i went to the shoulder turned it off waited for a hour for it to cool down i started it again turned on perfect. drove it for like 10 min and it did the samething. i thought it was the throttle body so i changed it but it wasnt it. did anyone have a similar problem to this.
Take off the timing belt engine and hand spin the crank till your marks line up and see if your crank is at the correct position. Mine was so bad I could spin the crank and the cam belt didn't even move.
