toggle menu
civicwagon.com
civicwagon.com
Sign In
Register
Sign In
Register
Sign In
Register
Home
Bodywork & Cosmetic Modifications
Removing dead pedal
Glifious
Wagonist
July 2011
in
What's the best way to get the dead pedal up? It's the only thing keeping the carpet in. I was working on stripping my 88 RT4WD and got stuck at the dead pedal.
bam-bam
Council Member
July 2011
Pry the tread part off with a small screwdriver, there are 2 bolts underneath.
Glifious
Wagonist
July 2011
Thanks bam. I tried with a screwdriver and bent it so I figured I was doing something wrong and didn't want to break it.
bam-bam
Council Member
July 2011
It just pops out- the textured flat insert on top, that is.
Glifious
Wagonist
July 2011
Got ya. Thanks again.
H_civic66
Senior Wagonist
July 2011
X 2. Super easy.
.JoshuA.
Wagonist
July 2011
so when the dead pedal is gone what is left? like a hole or still a hump in the floor board?
Ratrodwagon88
Band Wagon
July 2011
its layed over the carpet i believe so you should not have a hole
H_civic66
Senior Wagonist
July 2011
You will have 2 screws sticking out of 2 holes in the carpet.
Sign In
or
Register
to comment.
