i kn its been asked...
here is the problem. the ac on my 1.6l 89 rt4wd isnt workin. its a sanden compressor btw. so i proceed to evac the system. then pull a vac on system for 30 min to 45 somewhere in this area. go buy a retro fit, put the first can in compressor starts, but not cold.( 45 to 55psi) as recomended. doesnt cool at all.compressor seems to be running, yet no cool. when i idle up pressure bottoms out. still no cool. dont know where to find pressure switch, have no gauge to fit high side. has a smaller fitting than my manifold.
am i beating a dead horse. please help. its hot and the wifey is ill at lack of air.thus the nag nag nag...can i bypass the pressure switch to remedy this issue. oh in the sight glass i see no cloudy look. but system maintains constant pressure
You say the low side bottoms out? Like zero or less? That would mean a system restriction, possibly a bad expansion valve.
If your compressor is engaging, the pressure switch isn't the problem. It will disengage below 35psi or above 350ish.
The system will hold approximately 30 oz of 134a, so 2 1/2 cans. If you've only added 12 oz, I wouldn't expect it to cool yet. Put another in and see what happens.
