ECU??????????????????
Can anyone tell me if the ECU out of an 1989 Integtra is a direct fit into a 1991 AWD Wagon? I recently installed a Rover DOHC D16A8 and I was told it would be benificial to upgrade to the Intergra ECU. Looking at the two ECU's they have a different bolt pattern and the Led Code light is in different locations. Any help would be appreciated.
THANKS
THANKS
All i know is that it will plugin and work better than the crap PM6.
I run a PM7 in my Shuttle which bolts in no problems.
Don't you mean PG7?
PM7 bolts in and fits fine.
Theres three - PM6, PM7 and PG7.
The PM6 is from the Wagon and some other models, the PG7 is from the Integra and the PM7 is from JDM Civic/CRX Si with DOHC ZC.
Cheers
