British Build! - RT4WD Time Attack Build! - TWIN CHARGED
I warn you know. Make a cuppa or make some food, THEN come back, you will be busy for the next 20 minutes :top:
OFFICIAL MEGA UPDATE BEGINS!
From the VERY Beginning...
WARNING! The pictures are in order of me taking them, BUT! they are not in order of progress (IE - Wheels Refurb is spanned out across the update, Rather than in a single paragraph)
Picked her up! near 500 mile round trip, £165 in Diesel Later...
Back at base!
Underseal, EVERYWHERE
Random hole in the wing!
VERY tidy interior
Underseat Tray (Pointless bloody thing)
Mileage!
Engine bay before the work began...
EVERY nut and bolt in White Lithium grease!
Hole in the inner wing!
Boot Full of Crap!
Storage pockets!
Roof as Dull as a polished turd! (Noticed the Water channels have been greased and undersealed)
Let the transformation begin
Ripping it to bits!
Test fitting the winter wheels! (as you can tell!)
Testing the Watanabes!
HELLAFLUSH!?
TURBO!?!
Ripping ALL the civics apart...
Cause i dont fuck around when it comes to building Hondas!
Fitted the splitter (First of MANY)
Engine WIP!
Tucked Fusebox!
Colour Matching Washers
Rebuilding the MeisterR's
Wheels before i started to Refurb them!
Un-done! PAINfully slow process....
Barrel seriously corroded and in need of a good refurb!
After some HOURS of elbow grease...
Checking for rust in hidden spots...NON!
Relocated battery.
Dashmat!
Relocated MAP Sensor vacuum lines, Un-needed ones removed.
Supporting the Devil!
Wiring in Single Bulbs!
Shaving a spare rocker.
Fitting the Recaros.
The Rocker breather/ Water bypass pipe
Removed the pipes not needed
Relocated Engine Harness
Painting the Heat Shield
Elbow grease! REALLY nice colour!
Coilovers fitted.
More washers!
New Rad fitted, MORE washers, Heatshield fitted.
Fitted my Cock...
Wheels during Refurb.
VERY Clean! :top: Well looked after (Will explain)
More Tuckin..
Extending harness
Rot!
Recaros fitted.
SPOON BLUE
Watanabes shotblasted! Zinc primer, Grey primer then High Build primer.
Back from the blasters.
COLOUR!
Single bulbs fitted
Wheels done!
More wiring...
Adapting rails for Recaros...
DUMPED
RIP Splitter (Killed on its first EVERY drive on the road within 20 mins)
Not has 12 Months MOT.
Back to ripping it apart!
NEW nuts and bolts for the wheels! 70 of Each
Roof before polishing.
During
Prepping bumpers for Painting!
Plastic Primer
Grey primer
High Build
Colour
Done!
Wheels all done!
Bonnet Bra!
12x6 plates (Ultimate JDM y0!)
on Valver wheels
Watanabes finally finished!
On the road, Cam seal descided it didnt like to keep oil and liked to chuck it down the timing belt...
So i sorted this asap!
Engine bay after all the work!, Also WIP of timing belt...
eBay bargains! £50 for the lot!
Full D15/D16 head rebuild kit
New Tensioner
New water pump
New PAS Belt
New Alternator belt
New Timing belt
In bits...
New vs Old seal.
Organised chaos...
All back together! bleeding her up.
How she sits as of the other day!
Now! The Speech....
I took a week off work to work on the shuttle, In this week i did the Following...
-Paint Bumpers
-Refurb Watanabes
-Fit Recaros
-Fit Momo
-Fix Exhaust Blow
-Wiretuck Engine Bay
-Fit Intake
-New Radiator
-Polish entire Car
-MOT!
-Fit splitter
And a ton of other boring bits....
Currently, she doesnt look how i want. Due to the corroded coilovers i cant go lower on the Rear, The rear bumper is Saggy (Due to a rear shunt some time in its life), the front bumper sits to low (10mm gap under the lights), The Fogs dont sit right (Due to the bumper Sagging)
the VR6 splitter was killed on its first 20 miles on the road! i borrowed Trade Plates from work to get it to the MOT, got to work and the splitter had died! So swapped it for a GTi item. MUCH better.
The bonnet has VERY bad laquer peel (Alot worse than it is in the picks due to being weather), Drivers wing has a Random hole and is correded where the mudflap fits
The wheels where a NIGHTMARE! couldnt get the bolts undone. So i cut every single one off! and replace them all. I had to ordered some special valves as the ones fitted where badly corroded (3.50 PER valve) The nuts and bolts cost £30 all together (Inc Postage) Wheels painted in Body colour.
Theres alot ive missed out! but as i write this i cant think of anything!
Any Q's, just ask :top:
Back at base!
VERY tidy interior
Mileage!
Boot Full of Crap!
Storage pockets!
Ripping it to bits!
HELLAFLUSH!?
TURBO!?!
Engine WIP!
Tucked Fusebox!
Relocated battery.
Dashmat!
Coilovers fitted.
More washers!
Fitted my Cock...
More Tuckin..
Extending harness
Rot!
Recaros fitted.
SPOON BLUE
COLOUR!
Single bulbs fitted
Wheels done!
More wiring...
DUMPED
During
Plastic Primer
Grey primer
High Build
Colour
Done!
Wheels all done!
Bonnet Bra!
on Valver wheels
New Tensioner
New water pump
New PAS Belt
New Alternator belt
New Timing belt
In bits...
New vs Old seal.
Organised chaos...
Now! The Speech....
-Paint Bumpers
-Refurb Watanabes
-Fit Recaros
-Fit Momo
-Fix Exhaust Blow
-Fit Intake
-New Radiator
-Polish entire Car
-MOT!
-Fit splitter
Can you provide any info on the fog lights and measurements used to cut bumper.
There will be no asking for parts in member threads. If you want a part you post a WTB in the marketplace. Any soliciting of car parts outside the marketplace won't be tolerated. Ragenasian
Thanks,
Chuck
Long beach, CA
That shuttle cleaned up nice.
You fixing the rot?
I thought you had to, to pass MOT.
OEM Bosch Ones. If you look on the inside of the bumper, there are lines for 2 cut outs. Bosch and Stanley.
the BOSCH ones dont hold the JDM Tax like the Stanleys do
Rot was fixed for the MOT
I really like those wannabee's.
I guess they remind me of my panasports and my drag16's.
Plus I really like that maroon color.
Keep up the good work and keep us updated on the progress.
Do both of your wings have holes in the top or just one?
If it is both I think somebody had wing mirrors in them.
I saw on ebay somebody selling a set or rare shuttle wing mirrors.
It is that or somebody put an after market ariel in it.
Rich
Previous owner confirmed it was for an aftermarket ariel.
http://cgi.ebay.com/ebaymotors/88-91-Ci ... ccessories
what recaros are those?
also is that a montero/pajero towing it?
Decided to sort the front end! Sidelights didn't sit correctly, Bumper was all saggy and sat to low, which meant MASSIVE gaps. Fog lights don't sit properly etc.
So...
Before i started.
Off with its head!
Fog light Brackets
spaced out the Bumper bar, to Lift the bumper 2-3mm
Extended the bolt holes 5mm for extra adjustment
And extended the fog light bracket holes for more adjustment.
Sidelight Gap after
Front end after
Also fitted some new ARB drop links. 15 minute job!
Fitted some OSRAM Night breakers
And some Amber sidelights!
Wired up the Fogs Today
Done for this week!
Another update
Straightened out the rear bumper earlier...
Before.
Good paint for 23 years old!
After
:top:
Some Zeta-S coilovers and some CyberSpeed LCA's
Ride height before.
Old VS New
Old DCS's
Rebuilding, Regreasing
Making sure the Dust boots stay put!
White Lithium Grease! LOTS of it!
£3 inc VAT. Being in the Motor Trade Rules!
Making sure all the springs have the same, correct Pre-Load
MORE Grease!
Old VS New
More pics tomorrow....
Also fitted some new, Chrome Internal Drive wheel nuts for a bit of extra security. The old Red ones, Ive had for 3 years now and they have started to show their age, and the color has faded quite a lot on them, and they really let the wheels down. Wheels look 200x better with these new chromes ones. Really compliments the Polished bolts and really sets the wheels off!
Another thing as well, the Turbo WILL be delayed for at least another 2 months, and will NOT be turbo for JAE as promised.
Reason?
Well, the front suspension needs some TLC, the Radios Rod Bush's have gone and the steering is rather "Special". Overall the steering is Vague. I don't want 7psi put through a car i cant feel that well.
The engine also has a leak which i CANNOT source the location of! Ive changed the Cam seal, Crank seal, Sump Gasket and Rocker Gasket. Cleaned the block and it is STILL Leaking. So Ive had to go for some new Seals, using some better marked Pattern parts rather than eBay Specials i have installed.
I also want the car to LOOK 100% for JAE, so it will be going in for Paint in August. Which unfortunately, will not leave me enough funds to go Turbo, Unless i sell ALL my goodies for the EF2 (Spec 2, VT Lights, Looms, Charge speed etc).
So, Turbo will come September time!
Can you show us how you installed the recaros? I'm planning to do the same.
What car's LCAs did you use? Just fork-type for EF/DA? Or EG/DC?
Rebuilding shocks, I have some Zeals that I want to rebuild DIY because they are trying to charge me $350 each shock to rebuild! Figured it's only seals, how hard could it be? :P Or did you not rebuild them, did you just clean them up to look new again?
