F22b1 swap?
What's up guys.. I see the most common swap for an RT is the zc swap, but has anybody done an f22b1 swap out of a 94-97 accord? 2.2 single came vtec. I've seen it done to An EG hatch, and a crx. I don't see why it wouldn't work if used with an f2d kit, unless the wagons have a much tighter engine bay. Anybody have experience with this?
You will have to clearance the oil pan about 1 inch to clear.
Also The intermediate shaft will have to need a mounting bracket fabbed up just like the h2b
As far as hood clearance you dont have to worry about it since its about 2 inches higher then hatches.
ive been looking to an f22 turbo im glad someone else knows the glory of Fseries! cheap reliable and cast iron block!
this is going down.
viewtopic.php?f=5&t=4402
woah what? did you use a f2d kit or whats the deal here? Because I have 2 f-blocks in my garage that have no use
