Requesting how to for EDM center console install
please help me out and enlighten me if there is a step by step procedure for installing the edm lower console, i do not want to shove it into place and have broken tabs. thank you.
I don't have any literature on this subject and nothing came up on search about how to install one and before a mod decides he wants to lock this thread because he thinks this is common knowledge and shouldn't be asked, ask yourself, is everyone gonna have the same mindset and experience you've got to throw this into place?? I half do and half don't I can shove it into place but do not want to do that, I would like to do it properly, if someone has the procedure scanned from Honda, or write up, please direct me to it.
Ken
Ken
im not sure if there is really a right way to do it, but it is a pretty tight fit and if you dont want to shove it into place, i would suggest loosening the center console section that sits between the seats, that should help you wiggle it in easy enough...
i even took apart center console between the seats still didn't work.
you gotta be a jedi, you need the force.
pull down hard(don't break it) flex until upper side tabs slide in.
good luck.
This should be a 10 minute install tops, nothing difficult about it.
So what you're saying is to use the Usdm top half and attach it to the edm lower half, then install as a unit and it should fit and I don't have to wrestle the unit into the slot? If that's the case I've been doing it all wrong since I didn't use the Usdm top half! Thanks!
