A6 to Z6 swap: fast idle plug?
Swapping an obd1 ecu and D16z6 into the 89 RT4wd, the A6 motor has a fast idle valve with an electrical connector coming off of it.
The Z6 fast idle valve has no electrical connector or wires at all. I'm assuming the ecu doesn't need a signal from it, and it won't need one.
So do I just leave the plug on the harness unplugged? I'm going to call Rywire tomorrow (that's where i got my ECU conversion harness), but i thought maybe someone here would know.
THANKS!
-Doug
THANKS!
-Doug
