Rich car
What are some things that may cause my rt to run rich!?
Name them all!?(:
  • JakerJaker familEE
    Stuck injector
    Busted FPR
    Failing/failed O2 sensor
    Plugged air filter or restriction in the air intake tube
  • dre1162dre1162 Wagonist
    What's FPR!?
    fuel pressure regulator
    Would you happen to know how to test the o2 sensor!?
    Put a new one in and see if it's better. Don't forget to reset the ECU.
    How do you reset the ecu!?
    Disconnect the battery for 10 seconds. Reconnect it.
    or, just pull out the ECU fuse in the engine bax fuse box for ~10 seconds. (its easier, and you wont reset your clock and radio stations).
    Thanks that sounds great!(: very helpful will update soon
  • U can check it with a voltmeter.
